주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Acer Aspire 8920은 2008년 Acer, Inc.에서 출시한 노트북 컴퓨터 시리즈입니다. Acer는 대만 신베이시에 본사를 둔 전자 기업입니다. 8920 모델은 Gemstone 시리즈의 일환으로 출시되었으며 Acer에서 생산한 최초의 18.4인치 화면 노트북입니다.
laptop resetting during install
can anyone help my laptop keeps switching itself off and restarting during restore even if i use a stand alone windows not restore i have even tried from usb stick windows 7 BUT if iinstall linux or hackintosh its fine installs ok just i even have replaced the hard drive twice does it on windows any ideas
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
i think you forgot boot disk uttulities run over it
댓글 달기
답변 5개
Hello richardapayne
Sounds like a driver, a memory problem (not to sure why other OS's work though)
Does it restart at the same spot during the installation? If yes what is the installation doing at this time?
I would try running memtest86 for at lease 5 passes (I leave it run all night.)
http://www.memtest86.com/
When in Lunix run psensor to check your CPU temps. When installing Windows the CPU can max out and if the CPU gets to hot the computer will reset or turn off.
http://wpitchoune.net/blog/psensor/
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My aspire 8920g restarting with power is on.
In the mode safe works ok.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I had the same problem and after a bit of research I found out that disabling the two cpu cores in the device manager in safe mode solves the problem. Here's the link to the source: How to fix a notebook that freezes when plugged to AC power?
댓글 달기
that common in 2008 models. try to update bios. https://www.acer.com/ac/es/ES/content/su...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
The answer to this Reboot problem is the Capacitor located right under the CPU. Setting the CPU to use only a single core cpnfirms this is correct. There is a repair video on youtube that shows how to do this. The Original capacitor (Single Unit) is peeled off the board and replaced with 4 x 330uf - 2.5v Tantalum capacitors in its place.
It takes patience and care to complete, but is NOT too hard for most enthusiasts.
Whats needed: 2R5TPE330M9 330E 330 330UF 2.5V D SMD tantalum capacitors
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i have the same problem while trying to reinstall windows vista home premium because they got corrupted during a windows 10 installation and trying to boot results to a restart
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
richardapayne 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 2
지난 30일: 11
전체 시간: 2,599
