주요 콘텐츠로 건너뛰기
모델 A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, 또는 2.4 GHz Core 2 Duo 프로세서
1203 질문 전체 보기
질문 마감됨
Replace 1 GB memory module with 4 GB?
I have a 2.13 GHz MacBook5,2 (mid 2009) with 2 - 1 GB, 800 MHz memory modules. Would there be a problem if I replaced one of the modules with a PC2-6400 4GB module (IF111-038-1) for a total of 5GB of memory?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 4개
unibody does not come in 2.13ghz
It's a white case, if that helps...
Yeah it's not unibody its 1st gen type macbook look down at the answer your good to go !
Actually no it does'nt help your telling me unibody it says pro on the question and you have 2.13ghz, open your system profiler hit about this mac and tell me the ghz speed you got too much stuff going in this question.
댓글 달기
답변 3개
선택된 답변
No problem with taking it to 5GB.
Your machine is:
Apple MacBook "Core 2 Duo" 2.13 13" (White-09) Specs
Identifiers: Mid-2009 - MC240LL/A - MacBook5,2 - A1181 - 2330
http://www.everymac.com/systems/apple/ma...
RAM Type: PC2-6400 DDR2 Min. RAM Speed: 800 MHz
Details: Supports 800 MHz PC2-6400 DDR2 SDRAM.
Standard RAM: 2 GB Maximum RAM: 6 GB*
Details: 2 GB of RAM is installed as two 1 GB modules, no slots free.
*Apple officially supports a maximum of 4 GB of RAM but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If it's the regular first gen macbooks it will take up 6gb and PC2-6400 will work fine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If the ram is upgraded and hard drive is upped to 500GB can you run the latest version of Yosemite??
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This is an early 2009 Mac Book
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 280
