주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Epson Stylus Photo R2400은 Epson에서 제조하여 사진 애호가 및 전문가를 대상으로 판매하는 컬러 잉크젯 포토 프린터입니다.
Service Required message displays in print utility window
After changing an ink cartridge, my printer won't respond. The print head seems immobile, the top and middle lights blink on/off red (paper feed and ink cartridge change lights). A message in utility window says something about parts may be at or near the end of their life.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Did you use an original part or so called comparable ink?
의
댓글 달기
답변 1개
가장 유용한 답변
Answering for completion
This error is related to the WIC/waste ink pads. If you see the paper and ink lights flashing like this with this error, it's the waste ink with the cryptic Epson error. The newer ones usually say the ink pads are at the end of their service life.
It can be cleared with a leaked copy of the Epson adjustment tool, or WIC Reset Utility. However, you need to either divert the waste ink outside of the unit or take the entire thing apart to clean the pads out or it will make a mess. Some have a panel you can drill out or discard the inspection panel; others do not and you need to add the hole.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
crose 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 19
전체 시간: 518
