주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iPhone 3G의 향상된 버전으로, 더 빠른 처리 속도를 자랑합니다. 이 기기의 수리는 3G와 유사하며, 간단한 스크루드라이버와 도구만 있으면 됩니다. 모델 A1303 / 8, 16 또는 32GB 용량 / 검은색 또는 흰색 플라스틱 뒷면.
water damage...now working, but dim display
I fell in a pond with my iPhone in my pocket, but immediately took it out (15 sec. or less), dried it off the best I could, took the Sim card out and used a hair dryer (on low heat) to dry some more. I didn't know about the rice trick then. By the way, it was still working for about 15 minutes and I didn't realize I should have powered it off. Anyway, it will now start up, however the display is extremely dim to the point of being unusable really. I have tried resetting all of the settings and did a reset by holding the home and power buttons down. No luck, as it is still the same. Any ideas would be greatly appreciated. I am wondering if a cleaning may help things or I need a part. By the way the display works fine other wise.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
similar has happened me tried lots of things no joy
의
does it react in any way ? try the steps i wrote and you have a chance to fix it!
의
댓글 달기
답변 8개
선택된 해법
fluid damages can do serious damage to the phone
there is a white/greenish residue that shortens the parts, this residue must be removed
disassemble the phone, use one of the guides from te right (you didn't wrote what iphone model you have - thats why i can't provide a direct link for that)
use isopropyl alcohol (>90%) and a soft paintbrush to carefully clean the parts, don't forget the connectors
let the phone dry - without a hair dryer
reassemble it and try to power it on
good luck
이 답변이 도움이 되었나요?
점수 7
댓글 11개:
Thanks, it is an iPhone 3GS and will try the advice with fingers crossed.
의
The phone(3gs) is fully functioning but not the back light. What u reckon
의
gav - did you clean it like i described it? check the lcd connectors too!
의
Markus thanks for the help but didnt work still have a dim screen, phone is clean and dry inside and actually enjoyed dismantling it. Any other suggestions greatly appreciated
의
what exactly happend with the phone?
의
댓글 6개 더보기
댓글 달기
do i need to dismantle my iphone before putting it in a bag of rice??
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
it will help, you also want to remember that Rice is only a first aid. You should clean the phone with isopropyl alcohol to avoid corrosion damage later on.
의
forget the rice, a total waste of time
의
댓글 달기
will the rice still work even after its been left a few hours? or would of had to have been put in immediately for it to work?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
it might still work as a first aid to draw up some of the water. Again, rice does not fix electronic components.
의
thanks alot!
의
댓글 달기
Yes, rice will work even after a while, even after days. Rice will pull the moisture out. Sometimes there is permanent damage (rice won't fix this). Sometimes there's rust or corrosion which would require cleaning. Sometimes though, the moisture just causes a short (an example is my friend's iPhone button wouldn't work... it had been weeks). If the moisture is removed, it may fix some of the problems.
FYI: Silica packets also work.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
There is a coil on the mother board that powers up the display burns out due to water damage. Only way to fix this problem is to replace the 6R6 coil.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
sorry fluffy, that is not the right answer....:-) the coil is 6R8. There are also a few other things that one should try before replacing the coil....
의
Like what? What are the other things that I should try before replacing the coil?
의
댓글 달기
After a phone is submerged, first dry it off, then stick it in a bag of rice overnight, maybe even for a day or two. Rice pulls the moisture out of the internals. This is why they put rice in salt shakers, to absorb the moisture.
You could use silica packets or purchase one of the specialty "emergency" bags, but rice works just as well.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My phone has been doing exactly the same thing since it was half submerged in water, but all I can recommend is leaving your phone in rice for at least 48-72 hours since it got water damaged. I've heard a few stories of people doing this and there phone working like new!
Good luck all!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi I need help.. . I dropped my phone A10s Samsung in water, I've put it on rice but the problem now there is no brightness on the phone it's very dimm
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Did you find the solution?
의
댓글 달기
답변을 추가하세요
[deleted] 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 29
전체 시간: 63,774
