주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
phone works but touch screen is unresponsive after water damage.
I dropped just the top of my phone in water and it immediately went black. I soaked it in rice for 24 hours and it still wouldn't turn on. I brought it to a repair place where they cleaned it etc. They were able to get it to turn on, but I can't use it because the screen does not respond to my touch. They said it's a malfunction of the digitizer and for some reason there was nothing they could do. Is there any way to fix this? The screen isn't cracked or anything, the display is fine. If I replace the digitizer with one of your kits, should that fix the problem? What else can I do?
Thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 30
댓글 22개
What did you finally do to fix your screen Rosalind?
My mobile also have same problem
My tablet did not fall in water but something filled with water spilled on it. It was cracked up b4 this incident but the touch was still working. All the knobs are working (power button, volume buttons and home button) . it's coming on and I still get notifications but I have a pattern on it my touch is not responding.plz help. :"(
My phone touch is working easily but last line touch is not working so how can I use my phone?
My phone fell down from my hand there is a small crack as well. My screen isn't responding properly.e.g if I press "g" it wrongly types "q" or something else. If I keep my screen on and leave it the automatically starts working. Can I do anything at home.
댓글 17개 더보기
댓글 달기
답변 8개
선택된 해법
I'd suggest to call the shop to verify they tried another screen which I'd assume they did. When dealing with water damage most of the times is not only swapping parts out but actually working on the logic board. Rice is not helpful at all. Next time (hopefully there won't be) take it to a shop that can clean the board throughly right after the accident to avoid corrosion. A good shop should de solder all the shields on the motherboard and clean preferably with an ultrasonic cleaner.
이 답변이 도움이 되었나요?
점수 13
댓글 19개:
Hi Israel, thanks for reaching out. I doubt they replaced the screen simce they didnt charge me. But they said they cleaned everything. What do you suggest I do right now, since I don't plan on water damaging it again? Is there anything I can do to fix it, assuming the logic board has been cleaned but the screen jasnt been replaced?
I'd suggest to back up your phone if possible and take it to an Apple Store for a flat rate replacement
I dropped mine in water then after a few minutes the screen didn't move when I touched it.
Someone told me to take the phone apart and make sure everything is dry.
댓글 14개 더보기
댓글 달기
Any legitimate independent repair shop would have tested your phone with a new screen and attempted to sell you a new screen to make your phone functional. This means that you likely have board damage at the digitizer connector or elsewhere as is common.
Your best bet after water damage on an iPhone 6 is the $299 out of warranty replacement at Apple.
Also, skip the rice, it makes it worse and delays proper treatment while the phone is still wet.
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Ok, so you think they tried a screen and it didn't work? If I take my phone to apple they will offer me this deal? Thanks for your help!
Just came back from the Apple store and they offered me the deal...$299 for a refurbished 6. But I came home and for the !&&* of it plugged it in and it woke up...lines doen the screen and the touch screen isn't responding...actually showed the battery recharging...any further thoughts? The Genius Bar never tried to plug it in...took out the sim card though...asked him to put it back
yea i would say some damage to the female connector on the board for the digitizer
댓글 달기
hold down home button and power it will work it did for me
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
i had my phone go black for about a week and found this solution it just restarts your phone
I dropped mine in water and when I turned it on the home screen vibrates but the screen is unresponsive. what do I do? is it broken for good?
my screen was unresponsive after getting wet, but this worked for me
I don't have a home button..............
댓글 달기
Hi Rosalind. Did you tried this solution to fix unresponsive iPhone 6 http://www.unlockboot.com/2015/02/how-to...
It worked for me.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
d best way is to open the whole phone and clean it with alcahole and dry it,if not it will dry by it self and cause shortcircuit,
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
I dropped my phone in the water, i took it out immediately and dried it with a towel, then i switched on the phone, the touch screen wasnt working, i just removed the battery and let it dry...but it didnt work....its been 3-4 days since but still its not working...will putting my phone in a rice jar work? ...i did not try putting my phone in the rice jar earlier
Plz help i dont know what to do now
Never use rice
Use rice it worked for mine.just cause it didn't work for yours don't mean it won't work for others
댓글 달기
3 possibilities:
1. dead touch connector on screen
2. dead touch connector on logic board
3. dead touch chips on logic board
try another LCD, try to clean gentry the connectors with alchol and a toothbrush. if doesn't work - take it to the service to change chips.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had the same problem: Nokia 7 Plus, dropped into the toilet, the phone seemed to work except the touch screen did not respond to touch. I took it to a trustworthy repair shop (Fonum in Finland), and they had a look at it and said that it couldn’t be fixed.
However, my father-in-law insisted that if we soak it in isopropyl alcohol it would work (I think the idea is that isopropyl alcohol replaces the water, and eventually evaporates). As we didn’t have anything to lose we tried it out and it actually worked: the screen is now responding to touch, and the phone seems to work perfectly. The only downside is that the screen is now kind of messed up — looks like there are small amounts of liquid under the screen, and some other discoloring in parts of the screen — but I guess we could now replace it.
Thus, if you really need to get your phone working and nothing else works try to soak it in isopropyl alcohol. It will mess up your screen but it might make it responsive again. Note that we did this ~2 weeks after the water damage had occurred so you don’t need to try this as your first option.
****UPDATE****
A few days later, the screen is completely dead. The phone still works though (connects to a computer etc.)
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have a cheaper phone. Hisense infinity. Dropped it in the water, now the touch screen is unresponsive. The phone works but I can't access to it because of the screen glitches and not responding. What can I do. Please help
댓글 달기
I dropped my iPhone 6 in toilet. Next day I placed in zip lock bag with 4 silica gel sachets. Within 1 hour, it turned back on.
Update (11/18/2019)
It works ok. Do not put in rice or kitty litter-get the silica gel packets….as many as you can.
got all my data off the phone in case something happens.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rosalind Black 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 30
지난 7일: 181
지난 30일: 848
전체 시간: 597,214
