주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fiat Chrysler Automobiles US LLC의 Chrysler 사업부에서 생산한 자동차 및 기타 차량을 위한 수리 안내서와 지원.
cruise control quit working
nothing works with the cruise, the "cruise on " indicator light doesn't come on when I push the cruise on/off button on steering wheel
2012 town and country
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 12개
2006 dodge grand caravan. ABS and Break lights come on. I have never used cruise control. Bought it used 3 yes ago. When I turn off the engine the servo unit keeps running. WTD?
의 공유
I read all the comments and I'll be damned if hitting the steering wheel got mine working aswell!!! Woot! I use it ALL THE TIME! Was lost with out it! 2011 Chrysler Town and Country!
의 공유
I can’t believe it…it works! Two hard pounds to the back of the steering wheel near the cruise control switches BOOM ? Thank you to those that answered and commented!
의 공유
It also worked for me. How long? But it worked. Thank you
의 공유
Hello 2014 grand caravan with same issue , a little hit in the steering wheel and works! Thank you
의 공유
댓글 7개 더보기
댓글 달기
답변 13개
선택된 해법
john b , Defective speed sensor, bad cruise switch/wire connection, bad brake light switch,etc can cause cruise not to work properly. If engine light on, record the code to help diagnose the issue. You may have to find a good Tech. to diagnose and estimate repair. Good luck.
이 답변이 도움이 되었나요?
점수 5
댓글 53개:
Smacking the dash and steering wheel worked for me as well
의 공유
Son of a ##&&%, my cruise wasnt working, so i just smacked dash and steering wheel. Sure as $@$* it started working again lol
의 공유
Smacking the dash and wheel worked for us too! Thanks!
의 공유
Holy s@$&! Smacking the steering wheel worked for me too! I had to try it after reading the comments
의 공유
Holy crap!! Dash & wheel smack on my 2016 just worked for me, too!!!!! I don’t know if I love this or am really upset by it...
의 공유
댓글 48개 더보기
댓글 달기
가장 유용한 답변
I have a 2012 Dodge Charger. The cruise control on off button sticks or doesn't make contact to turn on. I have found that if you whack the steering wheel hard on the back side of the module a few times it will most likely start working again. I know this isn't ideal and the module needs replaced but it does work until you can replace it.
이 답변이 도움이 되었나요?
점수 20
댓글 32개:
We are on a long road trip to florida and the cruise quit. Started reading every post about it and found this one. Smacked the side of the steering wheel and I’ll be hanged if it dodnt turn back on.
의 공유
This just happened to me and it worked! Seriously!! Jeremy... did you do anything long term?
의 공유
It worked for me too!
의 공유
Unbelievable I'm driving down the freeway hit the back of my steering wheel and it works
의 공유
10/10. Worked in Canada too. Thanks Barry. You’re a genius.
의 공유
댓글 27개 더보기
댓글 달기
I have a 2014 T&C. I made a fist and smacked the side of the steering wheel (where the cruise control cluster of buttons is mounted) firmly 2x. I did not hit the buttons themselves or their housing directly. Result? Cruise icon lights up in the dash and cruise function works!
이 답변이 도움이 되었나요?
점수 7
댓글 2개:
Omg! It totally works!
의 공유
2011 300 the steering wheel smack worked. Unbelievable.
의 공유
댓글 달기
My wife has a 2012 T & C and turning ON the cruise was intermittent at best. I am an electronics tech, and decided to try spraying some electrical contact cleaner in the air gap around the ON/OFF switch in the steering wheel controls before going to the next level and replacing the switch. After applying the contact cleaner, I then dried it at the same point with a can of compressed air (computer keyboard cleaner). No more issues, cruise switch works every time now.
이 답변이 도움이 되었나요?
점수 5
댓글 9개:
Omg it worked for me too. 2012 grand caravan crew. Up here in Canada.
의 공유
I mean hitting the steering column and steering wheel.
의 공유
I have a 2012 crysler 200 cruise works sometimes and sometimes it doesn't what can I do
의 공유
So I thought all the comments above were a joke but.....it actually worked
의 공유
2015 Town & Country. No cruise, read the smack solution. Bam bam, works! Thanks!
의 공유
댓글 4개 더보기
댓글 달기
I also had a 2012 dodge journey that the cruise control quit working. I followed all the suggestions of checking fuses and break pedal switch and everything else but nothing worked. I then read this thread and went out and slapped the steering wheel by the controls and it started working.. I would highly recommend trying this first before checking anything else. I guess dirt food crumbs or anything else can get behind the buttons and stop it from engaging.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
That's crazy!!! I just tried this and it worked!!! I've been without cruise control for a few weeks. Amazing!!!
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Is the Check Engine light on? Alot of newer cars will disable the cruise control when the check engine light is on .
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
의 공유
댓글 달기
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
I removed the switch, opened it and cleaned the tiny connectors that were corroded where they touch the female connector from the wiring. The cruise control worked ever since…
의 공유
댓글 달기
I just worked on replacing brakes then my cruise control would not work. Thought it was a speed sensor but I have no warning lights on. Read these comments and I hit the steering wheel to see if that would fix it. Like magic it works now.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Holy Crap!! I googled this…My 2014 T&C Chrysler, cruise overnight Stopped working. Saw this, tried it, And It did work 🤗
Thank you!
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Was your brake, abs & anti skid lights illuminated at the time?
의 공유
댓글 달기
Just smacked it after driving four hours . WORKED WTF!!
SMACK IT!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Our cruise just went out on our "new" 2013 Caravan as we are headed back home from out of town. My DH loves using cruise control so he just asked me to Google "Grand Caravan cruise control issues." This thread came up and I thought the first comment was a joke. Then every comment was the same. My DH didn't believe it but started smacking the steering wheel. Nothing. One comment said to hit the center of the steering wheel. He said, "it's just the horn" but hit it anyway. The darn cruise control popped on! That is insane. We had a good laugh. Now, we don't know how to feel about this. It is obviously a defect.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
So my brake light went out, my ignition won’t catch til the second time then does immediately, cruise quit,it felt stuck ,not coming back up, smacked it and it felt normal again,orange engine light has been on, had it coded-no issues. One week before this all started the air intake sensor went down. Other than that she’s been running great..still no cruise control
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have a 2012 Dodge Durango RT. Cruise control stopped working. So glad I found this thread. Banged on the side of the steering wheel near the cruise control buttons. Boom. Like magic, cruise control works like it should! What a fix.
의 공유
댓글 달기
답변을 추가하세요
john b 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 52
지난 30일: 181
전체 시간: 66,295
