주요 콘텐츠로 건너뛰기
2.26 또는 2.4 GHz / 흰색 플라스틱 유니바디 인클로저
645 질문 전체 보기
Time to replace the Thermal Paste?
I've had my MacBook 2.26 GHz Core 2 Duo (13-inch Late 2009) MC207LL/A MacBook 6,1 - A1342 for going on three years this December, I bought it used through eBay and it's been running great after numerous upgrades / replaced parts including the Cooling Fan so I know that's not an issue.
I've Googled what the normal operating temperature should be and it seems to be in the normal range but suddenly the range keeps changing from 104° F to 122° F ( CPU die ) with the exhaust fan running at 6200 RPM + - ( smcFanControl ) but not holding steady or dropping below that range. ( Battery power )
Same readings with iStat Menus -
The only app running right now is Safari and CPU usage is not abnormal , Background processes aren't out of bounds.
Sensors check out, Could it be time to replace the Thermal Paste on the heatsink ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
선택된 답변
Make sure your fan vents are clean.
Here's how to get to the heat sink: MacBook Unibody Model A1342 Heat Sink Replacement
Here's a guide on replacing thermal paste: How to Apply Thermal Paste
Here's where to get the thermal paste: [연계 제품이 누락 또는 비활성화 됨: IF179-010]
Electronics Skills 이미지
안내서
난이도:
운영
5 - 20 minutes
MacBook Unibody Model A1342 Heat Sink 이미지
안내서
난이도:
어려움
15 - 30 minutes
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If the cooling fan is running then i would try and replace the thermal past just to see if that fixes the issue it it does not then the issue is something else. It is always best to start cheap then work your way up when fixing issues.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
David Bell 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 3,000
