주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
BLU Life 8은 안드로이드 4.2 기반의 스마트폰입니다. 720 x 1280 픽셀 해상도의 5인치 디스플레이가 탑재되어 있습니다.
How to unlock adb sidelock
why is my phone displaying 'now send the package you want to apply to the device with "adb" sidelock'
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
To be able to use adb you have to enable developer settings on the phone. To do this you open the settings menu and open about phone. In the about phone menu find the build number and tap on it repeatably about five times. You should see a message pop up saying your x amount of taps from becoming a developer. Once the developer options are enabled they will appear in the settings menu. In the developer options find android debugging and turn it on.
Now you need adb installed on your PC as well. You can do this a few ways on most operating systems. You can download Android Studio which has adb along with a bunch of other development tools. You can also download just adb and fast boot tools as a minimal download, which I recommend if you are not trying to develop android apps, ect.
Now with adb sideload you have to have the phone connected to the PC with android debugging turned on. To check if the PC recognizes the phone open a command line terminal and type: adb devices. If the PC recognizes the device and lists it then you know adb sideload should work. You can now use adb sideload in the command terminal to load the file on your phone. If you need more help with this you may also check out the xda forums.
Not sure if you are trying to figure out how to use adb sideload or if you are trying to figure out why your phone is wanting you to use adb sideload. Are you trying to install something? If so it may need to use adb sideload for it to work properly. With out more info its hard to give helpful answers, so I hope this is useful for you.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Now that my phone has let me do the wipe data factory reset, it is now displaying a picture of a Android and the word erasing. Now what do I do?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
NSCDC OYO CIVIL DEFENCE OYO 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 14
전체 시간: 810
