How do I change the number of rings?
how do I change the number of rings?
좋은 질문 입니까?
Hi @ n.marous,
In standby mode go to Menu > Answering Setup > Ring Time and select either 2, 4 or 6 rings.
Here is an auto download link to the D1788-2T User manual which may be of some help. Scroll to p.18
해당 답변은 도움이 되었습니까?
Thanks a lot for tips. at and t could not help me with this ptoblem
This is only possible with Uniden phone versions that come with the Answering Machine Function. The Phone version you have listed here is a D1760-2 which does not have an answering machine function. Unless yours does then please verify that the model number is correct.
Best!
해당 답변은 도움이 되었습니까?
My model is Dect 6.0 P.Rabe
E209700 is my uniden cordless model number. I want to set the ringer to 6 times before it goes to answering machine
Hi @thilary311,
Unfortunately your model phone doesn’t have any options to extend the ringing time. You can only temporarily silence the ringing signal for one call. The phone will ring again on the next call.
If you have a Voicemail feature connected to your landline phone service you may be able to extend the ring time before the call diverts to the Voicemail box. It might depend if you are on the maximum amount of time already or not. Usually it defaults to a lesser time, so you may be lucky
You would have to check on your landline phone service provider’s website how to do this as each provider has their own method. Alternatively, contact your landline phone service provider’s customer service section and ask them.
If you don’t have the Voicemail feature connected to your phone service then the ringing time may be adjustable, but again you would have to check with your landline service provider as above.
해당 답변은 도움이 되었습니까?
24 시간 전: 6
7일 전: 27
30일 전: 149
전체 시간: 20,703
댓글 11개
D1680 Series how to change number of rings
rjmc2911 의
it has always worked before.and we do have the answering machine function. DWX337 Waterproof Accessory Handset users guide. help not responding when we call posted numbers.
rjmc2911 의
I need to know how to change number of rings for a D1788-2T
n.marous 의
I do not have the model you answered above. I have a dect 6.0 with answering capability
James Pitts 의
n.marous 의
댓글 6개 더보기
