주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sanyo 텔레비전용 수리 안내서 및 지원입니다.
volume will not work with remote.
Volume can not be controlled with remote. Have to push the buttons manually
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 5개
All the buttons on the remote work. I did change the batteries.
The volume bar on television only show when the volume buttons are pushed manually, not when you push the volume button on remote.
의 공유
My Sanyo control volume does not work to turn volume down
의 공유
The vol go up and down by itself
의 공유
Why my 32 inch Sanyo go up and down by itself
의 공유
Volume goes down by itself
의 공유
댓글 달기
답변 4개
가장 유용한 답변
Are any of the other buttons working on the remote? Can you change channels or power it off or on?
If only the volume buttons are not working it is likely a problem with the remote control.
First of all, I would replace the batteries in the remote. If the batteries are getting low sometimes they can do flaky things. There may be enough power to make some things work(like power button) and not others (like volume button). Also make sure there is not corrosion in the battery compartment on the battery terminals. Old batteries can cause corrosion and make the batteries not have good contact and not supply adequate power.
If that doesn't work, I would purchase a universal remote and test it. If you did not want to buy a new device, some of the newer Samsung phones have Infrared blasters that allow you to use them as remote controls. You can download free remote control apps.
If a different remote doesn't work. The problem would be in the tv. If that is the case, perhaps someone else here with mnore knowledge than me.could assist with the actual tv repair.
이 답변이 도움이 되었나요?
점수 2
댓글 8개:
I can not turn the volume down manually. I replace the remote but still doesn't work what could be the problem
의 공유
My name is LaVerne and I have not been able to adjust the sound with the remote nor manually on certain movies. It is either too low or too high and I am unable to change it.
의 공유
There is nothing wrong with the batteries and yes all the other buttons work
의 공유
It has to be the tv that has the problem
의 공유
My tv is a 40” Sanyo
의 공유
댓글 3개 더보기
댓글 달기
Does a small panel appear on top right screen saying INPUT and HD . Reset the TV buy unplugging it for a few seconds, then plugging it back in. Fixed my problem..
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Go to the TV settings and change the Remote adaptivity. Keep the Remote on sunlight for 30 minutes this boost the battery power.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This sounds silly but mine wasn’t working because if you have tooo many thing on top were the señsor is it can’t read it take of all the junk you have on the table or where it’s located and it should work now.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
pam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 32
전체 시간: 13,291
