주요 콘텐츠로 건너뛰기
Nissan Motor Company Ltd./닛산 자동차가 제조한 자동차 수리 안내서 및 지원
689 질문 전체 보기
2006 Nissan Frontier dash light wont go away after sensor replacement
2006 Nissan Frontier. Dash warning light comes on. Have replaced both fuel sensors. Light stayed off for a week then came back on. Computer reads Catalytic converter needs to be replace. That said, it runs great! Good gas mileage, exhaust is great etc. what else could it possibly be?
Update (09/15/2015)
sorry! I meant the dash warning light. To clarify, both fuel sensors were replaced.
thank you so much for your help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
maria1519, what are your referring too by "both fuel sensors light up"?
댓글 달기
답변 1개
선택된 답변
Do you mean oxygen sensors when you say fuel sensors? What is the actual code that the obd is throwing. To test your catalytic converter measure the temperature on the pipes just before and just after the converter with a Infrared Thermometer . The engine should be warmed up and revving at 2000rpm when taking the temp. The temp should be higher after the converter if all is right with your CC. Let us know the codes and maybe we can help more
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
maria1519 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 135
