주요 콘텐츠로 건너뛰기
Repair and troubleshooting guides for the Braun Oral-B Sonic Complete 4729, a rechargeable electric toothbrush.
4 질문 전체 보기
Brush starts but won't shut off until relplaced in charger(switch?)
Oral B sonic starts and charges but won't shut off until replaced in charger
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
davidpeltier, Oral B sonic starts and charges but won't shut off, the off button may have slipped out of position inside the housing of the brush or the contacts may need cleaned. The disassembly link below may help in getting you inside the brush to check the switch. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Braun Oral-B Sonic Complete 4729 Battery Replacement
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Mine show thesma ebehaviour now. I took it apart ( search for batteryreplacement to find the procedure) and noticed a lot of corrosion inside. Probably the little on-off switch is corroed too. It is a switch on the smd circuit board. I will use a solder iron to take off and check if i can clean it or find a replacement switch.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
davidpeltier 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 18
지난 30일: 79
전체 시간: 25,203
