주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 2월에 출시된 10.1형 태블릿으로, Android 4.4 KitKat의 커스텀 버전을 탑재하고 있으며 모델 번호 SM-T520NZKAXAR로 식별됩니다.
Why isn't my front camera working?
I've tried taking pictures on my Samsung tablet but when I do the camera isn't actually taking any pictures. Neither is anything showing up in the camera app. The camera on the back still works, just the front one not working.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 달기
답변 2개
선택된 해법
Your device camera might have to be replaced or you might have a software issue. If it's a software issue; you can do a soft reset by holding down the power button for 8 seconds until the device turns off. If that method doesn't work you can do a hard reset of your device but make sure to perform a backup so you wont lose all of your data. If that method doesn't work you can put your device into recovery mode by holding these buttons at the same time while your device is off; power button, volume up, and home button. Use the volume button to scroll and select the option wipe device/factory reset. Then select all user data and press the power button to confirm. If this method doesn't work you might have to replace the motherboard. You can find replacement guides for the device on this page.
Samsung Galaxy Tab Pro 10.1 Troubleshooting
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Have you recently replaced replaced the glass ? Often when you replace glass the bonding material can cover the lens, or disconnecting the camera altogether. Hope this helps
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Stephen Yeung 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 10
전체 시간: 12,028
