주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 60D는 18MP DSLR(디지털 일안 반사식) 카메라로, 회전형 LCD 화면을 갖추고 있습니다. 이 카메라는 2010년 8월에 출시되었으며, 카메라 전면에 인쇄된 EOS 60D를 통해 모델을 식별할 수 있습니다.
HELP! Error Code 70
I keep receiving an error 70 code when I try taking photos. I turned the camera off and back on, but after several photos the error showed up again. Does anyone know how to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 1개
I get the Err 70 code to and can't do any thing else at all and after about a minute the camera shuts off. any help would be nice thanks
의 공유
댓글 달기
답변 6개
가장 유용한 답변
If the automatic sensor cleaning is enabled, it causes an error 70.
That is, the automation solution is put off.
But I do not know what is the reason behind it.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
thanks seems to have solved my problem "THANK YOU"
의 공유
댓글 달기
This is a memory card read/write error. First try to format the memory card. If the error continues after formatting (or the camera won't let you format the card), try a different memory card. If the error continues with a new card then you probably have an issue with the camera itself. Contact Canon for service. I hope this helps.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hey everyone.
My error 70 let me shoot in auto, CA, C1, C2 and C3 on my Canon 7d mark I.
After realizing I need to somehow update my firmware and that you cant update firmware unless in settings P, Tv, Av, M or B Ifound that if I set the camera to video I could use P and update the firmware I had loaded onto a formatted memory card!
Hope this helps someone else!
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had this problem toobut the solution is to deactivate the autocleaning. The it shoots nornaly
이 답변이 도움이 되었나요?
점수 0
댓글 4개:
I have this problem too and have format the card but still writing error 70
의 공유
Please help me
의 공유
Have AUTOCLEANING set to OFF
의 공유
Please check image Sensor
의 공유
댓글 달기
Hi, i fixed this error on my EOS 600D with Tornado EOS program. Do factory reset and problem solved.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
what do you mean Tornado EOS program?
의 공유
댓글 달기
I faced the same issue on my 60D.
Tornado EOS programn is really awesome! I used the free version to upgrade the firmware and problem solved!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tyler Vaal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 105
전체 시간: 27,007
