주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung에서 생산한 Galaxy Tab Pro 8.4는 2014년 1월에 출시된 안드로이드 기반 태블릿입니다.
Micro SD card is not recognised
I just put in a Samsung Micro SD card 16GB. My Galaxy Tab4 does not recognise the storage card. Did I install it correctly?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
There are a few issues that can limit the unit's ability to read a MicroSD card.
  1. First, have you made sure the card is compatible? Sometimes the card itself is a problem. Can happen. I use only x10 or faster units and have had no issues (At the Moment, I'm using a Samsung 64 gig card),
  2. Is the card CLEAN? Dirty cards with fingerprints on the metallic surfaces can be problematic although not usually so. But it can happen and using a slightly-damp towel is a plus (right after the shower anyone?),
  3. The orientation of the card is paramount when inserting. As you face the unit with the home button down and the loading port for the card on the left, make sure the logo (in this case, Samsung) is facing up and the largest squared off end is out, smaller side in, metallic side down.
  4. A satisfying, almost imperceptible *click* when it's inserted and is actually SEATED. Beware this one as it's important. I use the ROUNDED end of a paperclip to gently finish the parts my fat fingers can't reach.
After that, one should format the card if it's not done already by the unit's auto-magic formatting.
Settings > Storage > Erase SD card, the usual warnings about everything on it prior to it's being erased going bye-bye, yadda, yadda, yadda.
That's the procedure, your mileage may vary...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
baaleiavodah 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 3,601
