주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh Powerbook 140은 초기 Apple 노트북 컴퓨터였습니다. 이 노트북은 대형 전원 케이블, 배터리, 트랙 패드 대신 트랙볼을 포함하고 내장 플로피 디스크를 사용하는 최초의 Apple 컴퓨터 중 하나였으며, 키보드 높이를 조절할 수 있었습니다. 또한 키보드를 컴퓨터 본체 뒤쪽으로 장착한 최초의 노트북이었습니다.
How do I fix my screen?
Hello. If anyone knows about older Apple computers, I need your help. I recently got an old Macintosh Powerbook 140. I have plugged it in, and when I power it on, I hear the startup sound, and the speakers emit a tone, but the screen displays nothing. I have checked for any visible damage, and there appears to be none. It may be of note that the computer hasn't been used at all for the past 20 years. I do know that the last report of its use was that the screen was a bit touchy. 20 years ago, the screen could only be seen from the correct angle, but now there is nothing. Can anyone help?
I should also note that I have little experience with physical electronics. I work well with technical stuff, but I only have a basic understanding of electronic terms. If you could explain and terms for me, that would be great.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
Update: I have been getting tiny lines of light on the display for just a few seconds. not sure if it means anything but I thought it might be good to know.
의 공유
댓글 달기
답변 2개
선택된 해법
Sounds like a bad inverter. Move the screen back an forth and seem if you can discern anything on the screen.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I can't see anything on the screen when I tilt it or look from a different angle. i do however know that when it was last used, this solution worked, but it doesn't now.
의 공유
Proceed as Apple suggest:" No display, but computer appears to operate correctly.
1 Adjust screen contrast.
2 Check display cable, inverter board, interconnect board, daughterboard, and motherboard connections.
3 Replace inverter board.
4 Replace interconnect board.
5 Add shim to display cable. Refer to Additional Procedures.
6 Replace power cable.
7 Replace display cable.
8 Replace FSTN display (all repairers) or replace activematrix
display (CPRC/ international repairers only).
9 Replace daughterboard.
10 Replace motherboard.
의 공유
Ok. Could you explain some of the terms for me? I'm not great with the technical terminology. Also, I only have one external cable. It's the power cable. Should I have more?
의 공유
댓글 달기
hello
very common failure in these machines : LCD caps and inverter caps are gone , must recap lcd screen and inverter with new capacitors , i solved this problem with all my powerbooks 140-145b-160
see this video :https://www.youtube.com/watch?v=XP-fWaDb...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Jack 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 3,116
