주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2012년에 출시된 Monster DNA 헤드폰, 모델 번호는 MH DNA ON WHT CA WW입니다.
Why is one of the speakers working?
Whenever I use this device, I have found out that there is a problem with speaker because I think that the sound quality seems poor. What can I do in order to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 2개
가장 유용한 답변
My daughter had the same problem. Only one speaker working.
It turned out that the connector cable (the cable with the TRRS plugs on both sides; which transmits the signals from the audio source to the headphones) had a broken wire.
I found out by checking the conductivity of the cables with an ohmmeter, probing sequentially the corresponding segments of the TRRS connectors (if you don't know what a TRRS connector is, check on Wikipedia under "phone connector (audio)").
The cable is very flexible and is coated with a very soft rubber-like plastic. It invites rolling up the cable to a tight coil, or playing with it and bending it strongly while listening to music. This is how one of the wires may have broken.
So, before you dissassemble the headphones (and possibly damage them in the process), first check the cable leading to the headphones.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
In order to solve this problem, you should check to see if anything is blocking the speaker. If that is not the case, then there may be a loose internal wire or the speaker may need to be replaced.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Mesfer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 12
전체 시간: 3,036
