주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus X551CA는 일상적인 사용을 위한 편리한 기능을 갖춘 396.2 mm 노트북 컴퓨터입니다.
Keyboard malfunction,hardware or software problem?
Okay so i know this is not the keyboard itself because i have replaced it and didn't fix the problem. Scanned my whole computer and found no viruses, what the problem is, is that if i were to press key "3" that's above letter "E" it would show up as ".74231" if i press letter "E" the results i get are "hge9+" also the caps lock and spacebar act like this, not every key but about a handful of them do. I have already tried the "fn" "num lk" technique but it still does it.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 4개:
74231.7423174231.p7s 74231i have th74231i
I have the same problem! ugh. glad im not alone! all of the same problems although when i brought it to best buy to look at it they found nothing. they ..7423174231.74231.even kept it for a couple days and it didnt do it for them. but only for me. smh. i learned that if you slap the laptop with your hand, it will calm down for a few moments and stop...yup, the good ol fashion american way....lol.
의 공유
experiencing the same problem. Any updates? Please help me!!!!
의 공유
My guess is liquid damage / corrosion on keyboard connector, controller chip or circuit traces between kb connector and control chip.
의 공유
Tengo el mismo problema, además la tecla de la "barra espacio" escribe "nbz ". Lo curioso es que el problema desapareció en 2 ocasiones que no estuve conectado a internet (5 horas aproximadamente), pero luego volvió al conectarme a internet.
의 공유
댓글 달기
답변 3개
Your device is fine, its your key board. Junk the board and get a new one. I have two or more of these a month from friends an family. Ive worked on the boards to fix this isue. There is only one fix, a new key board.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I don't think you read what i had said, if its my keyboard then why did the other keyboard i ordered from EBay had the same problems? It was even tested and said to be fully functionable.
의 공유
댓글 달기
Had a similar problem with Shift “p” in order to print “P” I get “P&$@#!” instead and I get 74231 if I try to type “p”. The backspace also gives me sometimes 74231 and the cursor jumps to the begining of the line.
I actually had replaced the battery short time ago with a higher and stronger battery because there is no battery similar to the original one. It looks like the new battery fried the laptop.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have also the same problem. Now i connected wireless keyboard and it is working fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
redacted 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 35
전체 시간: 3,211
