주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Why isn't my tablet working
My tablet wont come on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
What have you tried? Charged it? New charger;new cable?
Can you try to describe your problem in detail? What is the situation of your tablet now?
My touch isn't working at all. Power and volume buttons are but no touch???? WATS wrong
댓글 달기
답변 3개
가장 유용한 답변
There may be a problem with the battery or charger, check out the Troubleshooting Guide for more information.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Have you tried charging the battery? If you plug in the tablet but the battery won't charge, the battery adapter may be broken. If so, try using a different battery adapter and see if that works. If you have exhausted these options and the tablet still does not turn on, then the problem may be with the tablet itself. In that case, you could try replacing the battery in the tablet because it may have run out of juice.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
The Reason Is Probably Because It Needs To Be Restarted.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Tina Stone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 19
전체 시간: 365
