주요 콘텐츠로 건너뛰기
나무와 바퀴. 각 다른 용도로 사용되는 다양한 종류의 스케이트보드가 있습니다. 스케이트보드의 기본 유형은 크루져, 롱보드 및 표준 트릭 보드로 분류됩니다.
Getting rid of paint: Sandpaper or Thinner?
Hi i recently rummaged through my Attic, and i found a great condition Longboard. I want to paint it so i removed the wheels and washed it. After it dried i want to get rid of the old green paint. The paint was kind of translucent, there's wood patterns on the paint.
I sanded it because it was the first thing that made sense. I use a 320 sandpaper. wasted an hour and 1 meter of sandpaper :c and i havent gotten through the paint. The paint seemed thick. I want a Clean Wood finish and paint The Great Waves off Kanagawa on it.
Do I use a rougher sandpaper or a paint thinner?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
Rashy, I'd try some paint remover (not thinner)to loosen the paint. Check this video for the exact instructions. After that I'd use the sand paper.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I'll try that. But im not sure my area sells those fancy schmancy paint remover
Try some regular paint removers. May not come off as nicely as with the fancy schmancy one and may need some more elbow grease, but give it a try.
I guess paint remover or sandpaper is not an option. the paint has seeped into the wood. so removing it would mean removing a layer of the wood from the skateboard. I tried 3 rounds of paint remover an leave them each 30 min. and not a desired effect, the paint barely came off although the ones that did came off is alot. i sanded it soft and planning to spray paint white.
댓글 달기
Definitely not sand paper as it can remove woods too. Also, rubbing sandpaper might rough the polish. So first go for paint thinner then use sand paper lightly.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Rashy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 11
전체 시간: 4,082
