주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Lenovo의 14인치 비즈니스 노트북인 Lenovo ThinkPad T430에 대한 수리 가이드 및 정보입니다.
Power button LED Blinks when I press power button.
Lenovo T430. Tried following steps, No luck. Refer to my Video here.
  • Try charging the Battery to Full
  • Remove Battery and tried booting it with Power directly.
  • Changed the Keyboard.
  • Removed the Bios Battery and tried to switch on.
  • Removed the RAM and tried to switch On.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 6개
Is there a pattern to the blinking?
No It just lits up and turns off. I dont think it is a pattern.
is there one or two sticks of ram
Do you get any fan sounds? Do you hear the hard drive spin up at all
yes i hear a fan sound, it comes and goes off (the sound)
댓글 1개 더보기
댓글 달기
답변 2개
선택된 해법
Try removing one stick of ram if you have two and test one stick at a time in each of the two ram slots. Then test the second stick of ram in both ram slots this will tell you if you have bad ram or a bad ram slot. if it still doesn't work you need to consider getting out a multi meter and tearing open your computer and testing the circuit board starting at the power outlet and working into the board
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
I tried the RAM swaps , no change. Also Fan wont turn on. I am not familiar with electronic circuits.
Even now 2021 i have that problem on my Lenovo All-in-One Computer IdeaCentre 300-23ISU (F0BY0041US) Intel Core i3 6th Gen 6100U (2.30 GHz) 8 GB DDR4 1 TB HDD 23" Touchscreen Windows 10 PRO 64-Bit
댓글 달기
I have a T430 with the same issue. LEDs (power Fn F3 ) are blinks one but the laptop does not turn on.
I triedtoclean the connections, remove the batteries....no change.
Once i removed the RAM and the unit booted up.
So the issue is the following : it works with no RAM, but it does not work with installed RAM.
The problem is the same with the old and a brand new RAM also.
Any idea?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
ksenthilbeit 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 12
전체 시간: 31,275
