주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Inspiron 15-3521은 15.6형 디스플레이와 선택 사양인 터치 스크린 기능을 갖추고 있습니다. 또한 무광 마감 처리와 숫자 패드가 포함된 키보드가 특징인 노트북입니다.
Why can't I install the usb driver?
After installing windows 10 there were a couple missing drivers. I troubleshooted the laptop in devices and printers and it fixed all the driver issues except for the USB2.0-CWR driver. It says it doesn't have it. I tried to update it from device manager but it says windows can't find the driver, go to the manufacturersame website. I couldn't find it on dell.com either. What should I do?
It says in properties that the drivers for this device are not installed. (Code 28)
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
have you updated windows 10 yet it could help
의
I'll try that thanx.
의
Ran a bunch of updates. Didn't change it. I had a problem on an hp pavilion recently where it didn't recognize the DVD drive. It seemed like a driver problem but was actually something in the registry that needed deleted and then it worked fine. Could this be something similar?
의
댓글 달기
답변 4개
선택된 해법
Hi,
Did you try this link, scroll to bottom and download Realtek USB 2.0 card reader?
http://www.driverscape.com/manufacturers.... If you have please ignore.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
Thanks, Jayeff, your link worked great.
의
댓글 달기
down load driver genius it should find the driver.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hey! It is easy! If you can't download drivers from official website, you can try to use a 3rd-party driver program to download driver for Windows 10. More detail: http://goo.gl/5h6ICN
이 답변이 도움이 되었나요?
점수 0
댓글 달기
maybe you should look for the driver Sesua, try visiting http://www.aiydriver.com and find your laptop drivers
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Jesse 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 11
전체 시간: 1,988
