My Bluetooth/Airport connector dislodged and stuck inside the socket
Hi, something weird happened to me. My bluetooth/airport flex connector broke apart where it connects into the socket. The whole docking part is now left within the socket and the flex cable now has just the leads and not that plastic box docking part. Is there any way to dislodge the connector from the socket without it being attached to the flex cable?
in this picture, you can see the bluetooth/airport socket and the flex cable part stuck within. I have no clue how to remove it. I tried using tape, it doesn't work. There is no space between the socket and the connector to insert something to jimmy it out.
좋은 질문 입니까?
댓글 2개
Does anyone think that if create a barb out of a needle, then heat that needle and lodge it into the center part of the male piece that connects into the socket, that I can get the piece to dislodge this way? .
NormButt 의
bump bump bump bump?
NormButt 의
