주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 12월에 출시된 삼성전자의 아시아 시장용 안드로이드 스마트폰이며, 다양한 모델 번호로 알려져 있습니다. 모델명 SM-A5000, SM-A5009, SM-A500F, SM-A500F1, SM-A500FQ, SM-A500FU, SM-A500G, SM-A500H, SM-A500HQ, SM-A500K, SM-A500L, SM-A500S, SM-A500YZ, SM-A500Y, SM-A500W을 포함합니다.
IMS Service has stopped
There is a message said, Unfortunately, IMS Service has stopped. I keep tapping the 'OK' button but still the message wont go out. Help please me as soon as possible.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 74
댓글 35개
I had this problem on my S5 neo when I upgraded my system to android 6.0.1. None of the solutions here worked for me, but the problem went away as soon as I rebooted my phone! :-D
의 공유
It's still doing it.i can not received mail.
의 공유
I hade this problem on my samsung galaxy j7 prime please help me
의 공유
Turn off the device.
Press and hold the Volume Up key and the Home key, then press and hold the Power key.
When the device logo screen displays, release only the Power key
When the Android logo displays, release all keys (‘Installing system update’ will show for about 30 – 60 seconds before showing the Android system recovery menu options).
Press the Volume down key several times key to highlight ‘wipe cache partition.’
Press the Power key to select.
Press the Volume down key to highlight ‘yes’ a press the Power key to select.
When the wipe cache partition is complete, ‘Reboot system now’ is highlighted.
Press the Power key to restart the device.
의 공유
hi, when i selected wipe cache partition and selected yes i got a msg as failed to wipe. help please. mine is a samsung j7prime
의 공유
댓글 30개 더보기
댓글 달기
답변 15개
선택된 해법
My partner did an update this morning, and it's been a disaster.... the IMS Service message has popped up all day long.
After searching on line for various 'cures' modified something, which seems to have worked on a Samsung Galaxy Neo 5. (I removed the mini SD card before hand)
Select MESSAGES
Select MORE
Select CONFIGURATION MESSAGE
Choose a previous version- I chose an August 2015 version
Select INSTALL
Let it download - an 'OK' message to say it has downloaded comes up
So far... no horrible pop-ups... and happiness is restored!
이 답변이 도움이 되었나요?
점수 28
댓글 13개:
No funcion ims
의 공유
IMS service has been stopped
의 공유
Bosilverman@live.com
의 공유
Non funaziona ims
의 공유
Samsung j7 prime ims service has stopped what to you meens
의 공유
댓글 8개 더보기
댓글 달기
This happened to me when I "synced" with "Cloud." I had to go into
Messages
More (right hand corner)
Settings
AT&T Messages Backup & Sync
Discontinue the Sync
이 답변이 도움이 되었나요?
점수 14
댓글 6개:
Worked like a charm.
의 공유
This was so simple!thank you
의 공유
Worked! Thanks you so much! It was driving me crazy!
의 공유
I did the same thing and it stopped the pop up, but my question is, what if I want my AT&T back up and sync turned on??
의 공유
I can't start my phone to go into settings. Now what Do I do?
의 공유
댓글 1개 더보기
댓글 달기
Similar answer to fix my S5 Neo:
Open Messaging (SMS)
Select More from top right menu
Then Settings
Choose Chat Settings
Tap on Rich Communications Settings and uncheck Rich Communications
Worked for me
이 답변이 도움이 되었나요?
점수 6
댓글 2개:
Same problem after restart or power up, with the message:
"IMS Service has stopped. "
Your solution worked perfectly.
Thank you.
의 공유
I don't have that on my S5
의 공유
댓글 달기
Hi Talulah
This is a copy from another site. It work's for me
After this, I did a restart with my Galaxy A3 2016
I had the same problem. Here's a fix:
1. Open 'Messages' (SMS app)
2. Go to 'Settings' in the top right (you need to scroll down to see 'Settings' from the options, as the defaul pop-up window isn't big enough to show all of them)
3. Select 'Default messaging app'
4. Select 'Rich Communications'
5. Uncheck the 'Rich Communications' box
This has stopped the 'Unfortunately IMS...' message appearing every few seconds on my S5.
Hope this works for you, too.
이 답변이 도움이 되었나요?
점수 4
댓글 3개:
Worked a treat!
의 공유
i looked for all you are asking and cant find any of this I have a note 5
의 공유
의 공유
댓글 달기
Go into app manager ...then tap more button select system apps from the drop down box ...scroll through for com.sec.ims select this app ...should look like a green bot/man there's an option to clear notification pop up ...this should do it along with clear any cache there too..
Samsung S5 neo only...that's my device and I had same problem after an OS update.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
STEP 1: ISOLATE THE PROBLEM IMMEDIATELY
As I said earlier, the error message “Unfortunately, com.sec.imsservice has stopped” can be caused by either a pre-installed app or downloaded one. So, to isolate the problem, you need to boot your Samsung Galaxy S5 in safe mode to temporarily disable all third-party apps.
Turn the device off.
Press and hold the Power key.
When ‘Samsung Galaxy S5’ appears on the screen, release the Power key.
Immediately after releasing the Power key, press and hold the Volume down key.
Continue to hold the Volume down key until the device finishes restarting.
Safe mode will display in the bottom left corner of the screen.
Release the Volume down key when you see Safe Mode.
STEP 2: DISABLE / UNINSTALL THIRD-PARTY MESSENGERS
If the error message doesn’t pop up while the phone is in safe mode, it means that one of your downloaded apps caused the problem. More often instant messaging apps are the primary cause of this problem, so find them and disable or uninstall them before you boot the phone in normal mode.
The purpose of this procedure is find which one is the culprit but apparently if you uninstalled all suspected apps, then you wouldn’t really know the specific app. If you’re really curious to know, I suggest you boot the phone normally and disable or uninstall suspected apps one after another until the error message won’t pop up anymore.
STEP 3: CLEAR THE CACHE AND DATA
If the error message still pops up even in safe mode, then none of your third-party apps is causing the problem. More often, when this problem happens and it’s not a third-party app that caused it, it’s the Contacts app or the IMS service itself.
Galaxy S5 owners who have encountered this problem reported clearing the cache and the data of both the Contacts app and the IMS service will fix the problem. So, here’s how you do it…
From any Home screen, tap Apps.
Tap Settings.
Scroll to ‘APPLICATIONS,’ then tap Application manager.
Swipe right to the ALL screen.
Scroll to and tap Contacts.
Tap Clear cache button.
Tap Clear data button, then OK.
Now find com.sec.imsservice and tap on it.
The error should have disappeared by now, however, if it still kept popping up, then the last step will take care of it.
STEP 4: MASTER RESET
If all else fails, there’s no other option but to backup all your data and perform master reset to give your phone a fresh start. After all, you just updated it to Lollipop. It’s the best time to set it up again and make it like new.
Press and hold the following three buttons at the same time: Volume Up key, Home key, and Power key.
When the phone vibrates, release the Power key but continue to press and hold the Volume Up key and the Home key.
When the Android System Recovery screen appears, release the Volume Up and Home keys.
Press the Volume down key several times key to highlight ‘wipe data / factory reset.’
Press Power button to select.
Press the Volume down key until ‘Yes — delete all user data’ is highlighted.
Press Power button to select and start the master reset.
When the master reset is complete, ‘Reboot system now’ is highlighted.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
this did not work and have done this several times been to store and no one knows what wrong with it
의 공유
I have a complaint regarding the repeated message , unfortunately , IMS service has stopped in my j2 Samsung mobile. Pls suggest
의 공유
I don't have that com.sec.imsservice
It is not under apps -> all apps.
Where else would be it be?
Tmobile Samsung s5
의 공유
I hot the top corner and had to select "Show system apps." But there is zero data under the com.sec.ims
and it is that and not com.sec.imsservice
Anyways, I set them all back to factory reset from the top right and it still didn't fix the problem.
의 공유
댓글 달기
ALL I know is
1. None of these solutions work. Tried them all.
2. Tmobile is utterly useless in life. ALL their reps. I’m sorry, but kindness doesn’t fix problems; knowledge and training on the issue does.
3. Samsung rep told me my phone was too old for service and she didn’t know anything about the s5…. a 2.5 year old phone.
2a. Will NEVER get a Tmobile plan as long as I live. Knowledgeable service is non-existent.
3a. I will never get a Samsung again because knowledgeable service is non-existent.
1a. I am about to throw this commie POS
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
IF this glitch came out when the phone did, they would have fixed it by now.
#SamsungCustomerSupport
#TmobileCustomerSupport
SMH… and the phone
의 공유
Something else to try, no cost ... have the phone store replace your SIM.
It's worked for a few of us...
의 공유
댓글 달기
I just had my Note 5's screen leak purple as if bruised. This Note 5 is my 4th Android. My phone was replaced with a S7 Active, and now I am seeing this IMS Service thing. None of the above fixes have worked.
HELP!!
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Messages
Settings
This worked great for me. I have a Galaxy also
의 공유
You must simply cancel Sync
의 공유
im having the same problem but i have a note 5
의 공유
On an S6 Active on Android 7.0, I had to go to Messages, menu (the three dots), Settings, Advanced Messaging, and turn off the Advanced Messaging feature - that stopped the annoying pop up from coming back.
의 공유
댓글 달기
i'm using galaxy g5, i had the same same problem, so i got into the message setting and disabled auto-retrieve under mms. i hoped it can help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Help to solve the problem for me pls...
I cannot use any of the solution above meanwhile I use Galaxy A7
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have this problem too my phone (Samsung galaxy j7 prime) keeps saying (IMS Service Has Stopped) ..... anyone knows how to fix it ? Please help .
의 공유
댓글 달기
I have a J7 and what worked for me is switching my default messaging app. I couldnt find the spots the other answers say so i changed my default to facebook messenger and it stopped. then i changed it back like 20 minutes later and it wasnt doing it anymore
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Kan de uitleg ook in Nederlands ik wordt ook gek van die irritante gelukt ieder minuut. Ik hou mijn telefoon constant op stil
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Change your default messaging app to Google's messages or facebook messenger, to do that go to settings>apps>threedots on top right corner>defalut apps>messages and change it to another one.this will definitely solve it, this is solved in my s8. This will occur after any kind of software update,there is no need to panic,just change the default messages app.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
MY RESOLUTION: Turn off WIFI Calling.
MY DEVICE: Samsung Galaxy S5 via T-Mobile.
ENVIRONMENT: Issue started when I got home and connected to WiFi at home. Particularly after Daylight’s Savings time turned off during the Summer.
WHAT IS IMS SERVICE? The IP Multimedia Subsystem (IMS) is a concept for an integrated network of telecommunications carriers that would facilitate the use of IP (Internet Protocol) for packet communications in all known forms over wireless or landline. Examples of such communications include traditional telephony, fax, e-mail, Internet access, Web services, Voice over IP (VoIP), instant messaging (IM), videoconference sessions and video on demand (VoD).
DID YOU RESTART THE PHONE? I did and this is how the problem started.
WHY DOES THIS WORK? The phone tells you it has a problem with your Voice Over IP Carrier Connection. I blame T-Mobile today as they host resources for me to VoIP over. Whatever. They still are awesome.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Methods to Fix IMS service has stopped error
Method 1: Uninstall any recently installed app.
Method 2: Wipe Cache Partition of Message App
Method 3: Wipe Cache Partition of Samsung
Method 4: Reset Configuration Message[worked]
https://fixyourandroid.com/how-to/how-to...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
daisy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 71
전체 시간: 351,992
