주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
스크린, 키보드, 배터리 문제를 해결하는 ASUS N56JN 노트북(ASUS N56 시리즈라고도 함)용 종합 수리 안내서입니다. 일반적인 하드웨어 문제에 대한 상세한 문제해결 단계와 해결책을 제공합니다.
Laptop not switching on.
I shut my laptop one night and didn't open it for two days. When I did open it up, I pressed the power button and nothing happened. So far I have left the battery out for 24 hours, plugged in the laptop, then the battery, and pressed power. I have held the power switch in all increments from 3 seconds until 50 seconds. I have single, double, triple pressed the button and help while either plugging in or replacing the battery.
I have checked the voltage at the wall. I am getting 19.3v from the transformer to the laptop. Voltage to the battery is 2.5v. Laptop gets 19.3v at the motherboard.
I have not been able to find information about proximity sensors/magnetic Reed switches but if there are, I can check them.
With all that said, am I looking at a bad power switch or possibly some other hardware issue? Just to be clear, the laptop does absolutely nothing when the button is pushed down. No lights, sound, nor anything that would indicate the laptop is booting.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 1개
same problem as above
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
dave 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 5
전체 시간: 692
