주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Cadillac Escalade는 Cadillac에서 설계 및 제조한 풀사이즈 럭셔리 SUV입니다. Cadillac이 인기 있는 SUV 시장에 진출한 첫 번째 주요 모델입니다. Escalade는 독일 및 일본 경쟁업체들과 Ford의 1998년 Lincoln Navigator 출시에 대응하기 위해 1999년형 모델로 처음 도입되었습니다.
heated seats not working
2011 escalade. heated seats not working
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Both seats or just one?
Both seats are not working check the fuse panel and the fuse was fine
I changed the module for heated and cooled seats do I have to program it
댓글 달기
답변 4개
선택된 해법
Check the fuses and relays and you may want to check that it didn't get unplugged by someone shoving something under the seat.
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
anyone know where is heater relay located?
댓글 달기
가장 유용한 답변
Have a 2007 check under the passenger seat, there is a module under the seat closest to the center counsel there is a bigger plug and two small plugs, checks the big plug to see if this plug is melted. Very common problem, of course no recall!!
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Where can I buy a new plug if this is the problem?
댓글 달기
If none of the above are the cause, pull back the seat cover and reconnect the frayed wire between the element between cover but above seat foam. The modules below foam wires thru the cushion so by clean splicing with new connector crimped at separation point where the wires got frayed, this should reestablish 10ohm resistance needed for heated element to work.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have a 2010 Escalade, I lost all function to drivers side seat, heat in passenger side, adjustable fuel and break, and steering column adjustment. All these functions are connected thru the drivers side seat memory module. The problem ended up being a plug on the memory module (the circuit card that remembers all the seat, pedal, steering positions, and seat heat monitor. So the big clues! All the devices are effected, intermittent or no problems until it quits. I had no issues.. I checked all fusses, disassembled drivers side seat, found no wire chaff issues or seat heater issues, Cadillac did a great job with wire mounting and wire movement areas. The module can be clearly viewed by looking under the driver side seat, mounted under metal support for cushion. If you have separate issues, look for that devise wiring and fuse.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
gomabtj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 40
전체 시간: 42,610
