주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mach Speed Technologies에서 제조한 Trio Stealth G4는 7.85인치 HD 터치 스크린을 탑재한 태블릿입니다. 이 기기는 Wi-Fi, Bluetooth 및 Google Play 기능을 지원하며, 쿼드 코어 프로세서와 전면 및 후면 카메라를 포함한 사양을 갖추고 있습니다.
Screen Cracked On The Tablet
Hi, I took my tablet to New York with me and didn't use it for the whole ride was going to though so I wouldn't be bored then on the next day, I open my case to my tablet to see that it was cracked. I did no physical damage to it. I thought the case was suppose to protect the tablet. Anyway, I have important information on it and I can't reset it because of the crack on my tablet. What should I do?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
What you need is a new digitizer screen for your tablet, while I have one here, I do not know how locall I am to you. I am in Michigan. Check a local company first for repairs. I charge twenty dollars for the screen and thirty dollars labor. Reach me at drslawinski2@gmail.com.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
What do I type in for the correct search local parts and service
댓글 달기
You can do what David Slawinski said and pay someone to repair it for you, but you can also repair it yourself for much cheaper :) This video will show you how
https://www.youtube.com/watch?v=ClSOlEdr...
You will need a heat gun or hairdryer the part is below it comes with all the other tools you need
For 7.85 inch: https://www.amazon.com/Atabletparts-Trio...
For 7 inch: https://www.amazon.com/Screen-Digitizer-...
An old credit card can be helpful for prying the old glass off. If you think you will want to repair stuff in the future I would suggest a toolkit, this is the one I have: https://www.amazon.com/dp/B00VJYWRKW?ref...
It is really nice, I fixit also makes some really good tool sets like this one: Essential Electronics Toolkit
Loosen adhesive or reflow solder with this 1500W heat gun. Low setting reaches 570 degrees F (300 degrees C). High setting reaches 1112 degrees F (600 degrees C). 이미지
제품
Heat Gun
$29.99
Our gateway kit to electronics repair, perfectly sized and priced for essential electronics repair. 이미지
제품
$29.95
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Stephane Caldwell 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 3
지난 30일: 16
전체 시간: 1,003
