주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell Streak는 2010년 8월 13일에 출시되었으며, 미국 AT&T 셀룰러 네트워크에서만 독점적으로 제공됩니다.
Can I replace the Speaker
The speaker on this device is totally rubbish. It cracks and crackles, the speakerphone is almost unusable. Is the part easily replaceable and if so can you recommend a compatible excellent replacement?
The ear speaker is also horrible in that you cannot hear anything unless you've absolutely directly paired your ear canal and the tiny slit. Any suggestions of a solution for a louder speaker here?
Thanks, Ravi Shanghavi, Ottawa
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 -1
댓글 달기
답변 1개
선택된 해법
이미지
이미지
I have had people tell me that "removing the cover over speaker helps with sound volume" so I gave it a try and will describe how to here. I will assume that you saw the teardown post for that is the best how to guide I've seen to date. For this mod you only need to remove the plastic bezel that covers the internal speaker.
Once cover is removed (it is held on with rather sticky tape so be careful not to crack it. I reccomend using the plastic tools shown in teardown post) locate the sticker covering the speaker
이미지
using tweezers, or whatever floats your boat, to peel off sticker.
이미지
Now simply replace the plastic bezel. I noticed a slight difference is sound, especially with directionality. I no longer have to have slit directly over my ear canal. Slightly off center works well now.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ravi Shanghavi 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 2,360
