주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Microsoft Surface Pro 2는 2013년에 출시된 태블릿과 노트북의 하이브리드 기기입니다. Surface Pro 2는 Microsoft의 Surface Pro 후속 모델이며, Windows 8.1에서 Windows 10까지 지원합니다.
Surface Pro 2 shutdown randomly
My surface Pro 2 shutdowns randomly without reasons, I've found a pattern: every 30 minutes with 0 seconds! exactly 30 minutes. Tried resetting, installing recovery image. I've had an issue installing recovery image: when I choose "fully clean the drive" after 30 minutes 0 seconds (33% installing) surface shutdowns by itself. I can only install the recovery image choosing the "just remove my files" option because takes less than 30 minutes. It's not a driver issue, not an OS issue, not heat issue, as crazy as it sound, it's a time issue (¿planned obsolescence?)
I CAN'T FULLY CLEAN THE DRIVE the Surface turns off by itself before finnish. I've contacted 4 times to Microsoft support and last time they were unable to get me another solution.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개:
you should try bios reset first and and seee
의
I've tried to reset from bios menu but there's no way to do it
의
댓글 달기
답변 2개
if your are really sure about the timing then i suggest you crack it open and disassemble the battery connector and do it with direct charger plugged in... and observe again
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
I've tried any mehod, I dissasembled and disconected the battery, tried to reset bios with this, reinstalled factory recovery without connecting battery, tested all without battery and shutdowns are stilll here. I don't want to assemble before try... i don't know what to try
의
try subjecting your device to a cooling device e.i.. direct a fan to the device as u power it on and observe the shutdown timing....
의
댓글 달기
Same issue here Anyone ?
These POS's need to be dumped on the corporate door step like the dung they are attempting to say is marketable.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
brunonemer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 21
전체 시간: 1,637
