주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
DualShock 2 아날로그 컨트롤러는 PlayStation 2와 함께 처음 등장했으며, 나사 위치 등 사소한 외관상의 변화만 있었습니다.
Left trigger not working
I took apart the controller to see and put it back together to see if maybe the button was just loose but that didn't seem to fix the issue. What would you suggest my next move be? I'm trying not to purchase a new one
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
The bottom triggers are tricky to reassemble. You probably didn't do it right. You need to feel the popping of the button. If it doesn't feel like there is two states, then you need to reassemble it.
의 공유
댓글 달기
답변 4개
선택된 해법
If your comfortable taking it apart again clean everything with isopropal alcohol. Sweat from your hands gets into the controller and gums up the functionality of the controller. If the feel of the button is off dead feeling it may be plan broke but if it still feels right a good cleaning can do wonders
DualShock 2 분해
Hope this helps
이 답변이 도움이 되었나요?
점수 7
댓글 1개:
Thanks! I'll give it a try!
의 공유
댓글 달기
Is the L1 button not working or the L2? If the L2 button is not working, you can pop it off the assembled controller with a Spudger. When you do that, you should see the rubber buttons that the L2 button pushes down on.
Realign the rubber button and rubber strip into the plastic channel and then put the hard L2 button back on (pinch the sides of the button gently and then insert them back into the assembled controller, they should snap in place).
After that, try the L2 button; you should hear a clicking sound.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
It sounds like you wore out your controller. You could repair it or just get another controller. I wouldn’t mess with it, I would get another controller.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
the connection port of my controller got one pin missing…… what should I do…. please help !!!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ricardo Martinez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 8
지난 7일: 20
지난 30일: 89
전체 시간: 16,447
