주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy S6 Edge+는 Galaxy S6 Edge 스마트폰의 커진 버전입니다. 충전 문제
Front Glass Replacement for Galaxy S6 Edge+ Plus?
I have been looking for a replacement screen for the past 2 months. (Screen broke 1 month after buying the phone.. WITH A CASE ON IT!) It still works but Its a big eyesore.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 10개
선택된 해법
If the glass gets damaged, the easier and safer solution is to replace the complete screen assembly since the glass, digitizer and LCD screen are bonded together tightly by the help of very strong adhesive, and it is very hard to separate neither of them for individuals. Though there is front glass replacement sold separately. The reason is that it is possible to remove the glass from the LCD, as long as you have special tools as well as professional skill. Otherwise, it is better to replace the whole assembly rather than just the glass. Here is the s6 edge+ screen replacement from the third party: http://www.witrigs.com/oem-lcd-with-digi...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I wonder how much Samsung charges for a screen replacement because it is definitely cheaper than anywhere else for S6 edge and higher in Australia.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I can help you it it's easy as 1 2 3 add me on Facebook jp Joseph
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I agree with kristastic1990 ... however it might be cheaper to buy a second hand S6 edge on eBay and then sell your broken glass s6 edge back on eBay ... difference might only be $100 - $150 as people with the right machines will buy it to refurbish the glass only.
Please do not attempt to a glass only replacement. I have been a tech for 5 years with mobile devices and its just not a feasible repair.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
You'd better replace the whole AMOLED display, only replace the glass is very difficult and need some equipment. Here is about how to replace Samsung Galaxy S6 Edge + display. Samsung Galaxy S6 Edge Plus 분해 방법
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
jpride56j5 how can I get intouch with you ? I've got a s6 edge plus that needs a new screen ? Thanks
댓글 달기
I don't know how you have searched for replacement screen. My first suggestion for you is to replace the screen at Samsung store. It might cost a lot, but reliable. You can also just find a common repair store, which should be cheaper. Or, you can buy a replacement screen online and install it yourself. Alibaba should have the cheapest screen. But, sharpen your eyes.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
See for yourself! Repair stores refuse to even try to fix it! I wouldnt ask here if I didnt look before.
댓글 달기
My Brother in Law says the 6 edge plus can't be taken apart, can I get the answer on this ? Yes we're fusing over it lol .
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
It can, but isn't the easiest of phones for disassembly, quite a bit of adhesive is used to hold the front and back in, and to service a lot of the stuff, the screen needs to be removed.
댓글 달기
samsung s6 edge front glass change
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Yes
I want to replace samsung. S6 edge. Plus screen. Display
What. Will I do
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Samsung 6 edge plus replace screen
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
REYESRZA 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 28
전체 시간: 27,602
