주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
발표 - 2014년 11월 Samsung Galaxy Core Prime (G360, G361)은 1.3GHz quad-core 프로세서로 작동하며 1GB RAM을 제공합니다. 휴대폰은 8GB 내부 저장 용량을 제공하며 microSD 카드를 사용하여 최대 64GB까지 확장할 수 있습니다.
Phone is not turning on
I was browsing through net then suddenly my touchpad stopped working. Display was clear though but touchpad was not working. Then i googled about it and came to know that i have to remove the battery and press the power button for 60seconds and then place the battery back and switch it on. But after placing the battery back, The phone is not getting switched on
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
What was the battery percentage before it turned off? Does your battery drain fast or have you noticed anything like this before?
There might be a chance you just need a new battery. If you have owned that phone for awhile and it is the original battery - batteries eventually just need to be replaced over time. I would test to see if that is the issue.
I hope that helps.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
No the battery was like 25%, and like i said i switched it off. and then pressed power button for 60secs and then tried starting it.
의
댓글 달기
답변을 추가하세요
Gourav Agarwal 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 13
전체 시간: 1,870
