How do I fix the broken charge port?
Will not charge. The inside of the charger is broken.
좋은 질문 입니까?
좋은 질문 입니까?
I don't think the charge port is USB, it uses a mini cord that should slip over the contact.
해당 답변은 도움이 되었습니까?
i think you need to resolder that USB port
go to ifixit youtube channel and check out resolder of USB port on SGS3, on SGT4 it should be the same
i don't think SGT4 has USB port on doughterboard (so you just replace that little piece )
resoldering that without equipment is nearly impossible
you can buy tools and DIY but it's gonna cost you a bit
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 803
댓글 1개
I had the same problem with device purchased May 2015. I just received replacement unit 2 days ago and again have same problem!
troyerdd 의
