주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung에서 생산한 Galaxy Tab Pro 8.4는 2014년 1월에 출시된 안드로이드 기반 태블릿입니다.
charging port does not work
The pin inside the charging port seem to be broken.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
선택된 해법
i think you just answer your own question.
이 답변이 도움이 되었나요?
점수 1
댓글 4개:
Well, not really. I was hoping for some advice on how to get access to the plug. I didn't find any repair videos on YouTube and no repair manuals
의 공유
Ok, that's a better question. If your problem is the port as you say, you have to swap charging flex cable which is pretty simple compared to Samsung normal approach of soldering port to the motherboard.
Here is a link how to open the tablet
https://www.youtube.com/watch?v=lEVFYQks... (0:25 - 2:20 time)
And here is link to buy DOCK CHARGING FLEX CABLE http://www.parts4repair.com/dock-chargin...
When removing old port from the device be carefull not to damage pinheads in the process. Hope this was more helpfull and gives you enough information to proceed with the repair. Good luck.
의 공유
Thanks a lot. I am afraid my first question went into cyberspace in an amputated version.
의 공유
does the port pull out or do you have to remove the plastic on top of it
의 공유
댓글 달기
Is there instructions on how to remove the charging port or flex cable?
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
yes is understad
의 공유
was good and wounderfull
의 공유
댓글 달기
답변을 추가하세요
terje 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 17
전체 시간: 1,207
