주요 콘텐츠로 건너뛰기
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
227 질문 전체 보기
Swollen battery affecting middle button.
Old first generation iPod "brick" required new battery 4 years ago that was swollen and preventing middle button from functioning. Apple retailer did repairs but now Apple is prohibiting their stores from working on discontinued products or even ordering parts. This is a relic that still works great. Appreciate any suggestions or options vs. purchasing a replacement.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Joe, lets identify your iPod properly first. The first generation iPod did not exist as a 60Gb model. What is the AXXXX number of your iPod? What repairs were done and what are the issues now?
Model No. A1099, EMC No. 2022. Circa 2004. Sorry, may have been ill advised regarding what generation it is.
4 years ago the center button became stiff and unresponsive. Turned out the battery was going bad and characteristically swells in the center right under the center button. The ring and other controls were not affected. Local Apple reseller tech easily repaired it. Same problem has now reoccurred, and the same Apple tech that fixed it last time feels it's the same issue. But, Apple now prohibits him from working the device.
댓글 달기
답변 2개
선택된 답변
Joe, first thing you want to do is to open it up. Use this guide for that. Discard the battery properly and of course replace with a new one. At this time I would consider replacing the click wheel. A replacement may be a bit hard to find, but they are still around. Follow this guide for that and as a last step remove the clickwheel. It is simply glued in to the front panel
iPod 4th Generation or Photo Battery 이미지
안내서
iPod 4th Generation or Photo Battery Replacement
난이도:
운영
15 minutes - 1 hour
iPod 4th Generation or Photo Logic Board 이미지
안내서
iPod 4th Generation or Photo Logic Board Replacement
난이도:
운영
20 - 45 minutes
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I'm guessing you have an iPod Video 60GB. You can get the part from iFixIt:
iPod Video 60/80 GB Battery
Here's the repair guide (make sure your iPod is the same as this before ordering the battery):
iPod 5th Generation (Video) Battery Replacement
iPod Video 60/80 GB Battery 이미지
상품
$13.99
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
귀하의 답변을 추가하세요
Joe 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 296
