주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1347과 2.4 또는 2.66 GHz Core 2 Duo 프로세서.
Need a workaround for installing older Mac Operating systems
Many times I need to install an operating system other than the current one a machine is running from. I hook up a drive externally with an adapter, go to install but my machine tells me I can't do it because the operating system is newer. I can't get to the drive to select it. i.e. The MacPro is running 10.11.2 but I need to install 10.9 on an external drive to go into say a MacBook Pro 2009. Is there a workaround?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개:
I'm not sure if this is what your after but have you ever tried running it through a VM . With a VM you can run any OS within the OS you are presently using. I run several different OS on my laptop to be compatible with different systems at work .I work in robotics and most of the systems are in Linux and not all the same so I use a program called VM ware that creates a virtual machine that can be whatever OS I happen to need . I just switch to whatever OS is required I presently have 3 different Linux and an old version of windows running on my laptop with windows 10 as my main OS. I know Mac work with this as you can use it to load a windows OS on your mac
의
There are different VMs available I us VMware workstation but for Mac I think its called VMware fusion
의
댓글 달기
답변 1개
Follow one of the many guides online to copy OSX install media onto a USB stick. Boot from it, and you should be able to install OSX to an external drive.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
mayer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 636
