주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1984년 "Apple Macintosh"로 처음 출시한 원래 Macintosh 데스크탑 컴퓨터입니다.
Sad Mac Face & error code 040090
This one got sent into me for repair. I'm getting a Sad Mc face and error code 040090. I don't remember what this code indicates. Anyone have an idea?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 2개
Thanks to the link Old Turkey sent me the machine is now running with ram replaced then the caps replaced by the same guy after it failed.
MacCaps.com
MACCAPS.COM 
22222 ROETHEL DRIVE
SUITE D
NOVI, MICHIGAN 48375
UNITED STATES
Charles Phillips
248 325 8812
의 공유
I had sad face error code 024000?
의 공유
댓글 달기
답변 4개
선택된 해법
04XXXX = Memory test - Mod3 test Memory chip failure
이 답변이 도움이 되었나요?
점수 4
댓글 11개:
That would be ICs on the logic board itself. Do you know if they are removable? If so where would I find replacements?
의 공유
mayer, try this first while I keep trying to find out more. Sad Mac codes can also have a less serious causes such as:
A non-system disk in the default drive
A bad boot disk
An incompatible system file on the boot disk
No Finder on the boot disk
A sticky Programmer's switch
의 공유
The startup disk could be a possibility. Will dig in the file cabinet of hundreds of floppy disks to see if I can find an original.
의 공유
I get this code with no disk installed. Time for a tear down.
의 공유
Pulled board, unable to determine any visible damage to soldered in RAM chips. Any idea of where to get replacement chips?
의 공유
댓글 6개 더보기
댓글 달기
Mayer
We could have similar problems and may be able to help one another in finding a solution. First, where are you (I'm in Australia)? Second, do you get the sad safe following the "dong", and before a disk is inserted? And third do you understand the other possibilities that Oldturkey03 suggested (nonsystem disk in the default drive etc). As far as I can tell none of these are relevant because the 04 prefix to our errors (mine is 048360) means a RAM chip on the logic board.
Looking forward to your reply.
Barry Richardson
brlund007@gmail.com
이 답변이 도움이 되었나요?
점수 2
댓글 1개:
I dropped in a 512k board. Machine booted just fine, so Disk is good. Ran initial RAM tests. All good! Ran extended tests for an hour and a half, burned out the power supply :-(
의 공유
댓글 달기
Replace the RAM Chips..
I hope it works :)
이 답변이 도움이 되었나요?
점수 0
댓글 6개:
If you read the question, you'd know it worked.
의 공유
How would he know that? I just looked again and even after reading through a bunch of follow up questions I still don't know. Why not say 'yes or did not work' instead of giving people a nasty attitude. You had the help from others , too . SMH
의 공유
MY FIRST COMMENT WAS "
Thanks to the link Old Turkey sent me the machine is now running with ram replaced then the caps replaced by the same guy after it failed."
MacCaps.com
MACCAPS.COM 
22222 ROETHEL DRIVE
SUITE D
UNITED STATES
Charles Phillips
248 325 8812
의 공유
why do I keep getting told I've heped lots of people when I've done bugger-all?
Barry
의 공유
@rhodas007 That happens when you hang around in questions that @oldturkey03 and I are involved with ;-)
의 공유
댓글 1개 더보기
댓글 달기
Hi,
my beloved really early 128k comes up with a SadMac code 041004 and some fragments on the screen.
I did a quick video on this issue: https://youtu.be/Cql6E2PxGj0
Any advice would be great - if it's just the RAM (I fear so) where to get them?
Marcus (@marnoweb.de)
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Please read through the discourse on this page. MacCaps can handle this for you.
의 공유
THX, but I finally tried it with swapping the DRAMs - with success :D
의 공유
댓글 달기
답변을 추가하세요
mayer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 40
전체 시간: 2,855
