주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 Apple Cinema Display는 M8149 모델 번호로 구별되며 2000년 7월에 처음 출시되었습니다.
pink or red screen fix
I have two 20" apple cinema displays and one of them started giving a pink/red tint to the screen image. I was wondering if this is a common problem with a solution that I can repair myself. Any advice would be greatly appreciated! Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
Check the number please, is this a A1081?
의
The number a1038 is the correct numer on my display. It is an older model with the clear acrylic body. It is not the model a1081.
의
The same is happening to my 22" Cinema Display ( 2000 ). Except it happens intermittently. And the change between normal and orange seemed to be always after the screen was moved.
의
댓글 달기
답변 2개
가장 유용한 답변
Reddish color on any monitor/display is a faulty LCD.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
When I had this problem on my M8536, it was just because of a faulty cable. Try bending the cable around and see if you can find a sweet spot in which the picture has the appropriate colors.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
legendmacnet 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 19
전체 시간: 1,524
