Why is my jbl charge 2 without sound
After charging completely my jbl charge 2 i turned on, i connected without any problem but the sound doesn't comes out. waiting for prompt response.
Thank You
좋은 질문 입니까?
Thank You
좋은 질문 입니까?
I have the same problem,:
- my jbl charge 2 is fully charged
- I switch it on without problem and lights of Power button and sounds level are all ON
=> it doesn't make any "beep" sounds when it turns on as before
- I have no problem to pair it with my iPhone, it is recognized by Airplay
=> I do not get any sound when I play music on my Smartphone
=> I do not get any sound if I connect using a stereo audio cable connected to the 3.5mm aux input as per jayeff question
I have opened the casing but do not see any special damaged items in it... do I have to change the speakers? Do I have to change the electronic card? Any suggestions or guidelines ?
Thanks for your prompt response and advises.
해당 답변은 도움이 되었습니까?
My charge 2 plus has been fully charged but now havnt any beep sound or music sound
any one else can Help me ??
Hello, I took mine apart and the resistor is cracked. Can you provide any information on how you replaced yours? The video that is in Russian appears that the user was able to glue it back on.
Thanks in advance for your time!
I have the same problem...what can do ?.. firstly what is the problem?
Did y'all try to connect and play in a very low volume???
My JBL Charge 2 still play in a very low volume but when I try to increase it, the sound stops suddenly.
Does anybody can help me, pls?
해당 답변은 도움이 되었습니까?
Took mine apart, was able to determine the problem was the said resistor, my challenge here in Nigeria is getting a replacement...
해당 답변은 도움이 되었습니까?
I to had the same issue and fixed my resistor with hot glue just like he did. Works like new now
해당 답변은 도움이 되었습니까?
My JBL is acting funny. Red light blinking, static, goes on & off. When I hook it up with a cable does the same thing.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 24
30일 전: 118
전체 시간: 34,961
8 댓글
Hi,
Do you get any sound if you connect using a stereo audio cable connected to the 3.5mm aux input?
jayeff 의
https://www.youtube.com/watch?v=Ok4yYOZg... This is the guide (in Russian). It shows the reason of your problem
varggot 의
Thanks a lot Varggot, this was the problem. The resistor was broken and I fixed it !
David Bertet 의
i want to TearnDown my Charge2+ but i think this is not my problem ☹️how can i see exactly wrong and problem
SalehEVO 의
My jbl charge 2 + volume doesn't go up, I can hear music playing but it's very low, it only works on Bluetooth and the when I play from the Aux there is no sound at all. It is fully charged and I even reset it. Can someone please help me?!
tahahaji52 의
3에 댓글 더 나타내기
