주요 콘텐츠로 건너뛰기
2008년 10월 출시 / 2.4, 2.53, 2.66, 2.8 또는 2.93 GHz Core 2 Duo 프로세서
376 질문 전체 보기
2008 MacBook Pro backlight not working
Hi,
I have a 2008 macbook pro 15" A1286 with a 820-2330 board but the backlight is not working. Would somebody mind showing me where the backlight fuse is located so I could try replacing that? Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
@cmkorkis here is the location for the fuse. it is F9800 and is a 2Amp 32V in a 0402 package. U9701 is the LED driver. This is just to point out your fuse, not to diagnose your backlight circuitry.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
Which one would you recommend for attempting to fix the backlight out of the three you highlighted? The LCD cable was missing a pin and I believe that is what blew the backlight if that helps at all. Thanks @oldturkey03
F9800 check for continuity. If you had a pin missing, your connector may be at fault. You have to make sure it is not the cause of the short circuit. The fuses are available at places like digikey.com or mouser.com
How would you check for continuity? Sorry, Im kinda new to this stuff. Thanks@oldturkey03
Check this site to see how to do that. You test your SMD fuse the same way as pointed out on that site.
댓글 달기
귀하의 답변을 추가하세요
Christian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 2,181
