주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xperia Z1 Compact는 Sony의 프리미엄 카메라 스마트폰입니다. Xperia Z1 모델과 비슷하지만 더 작고 가격이 저렴합니다. 주요 기능은 20.7 메가픽셀 이미지 센서입니다. 출시 당시 사용 가능한 색상은 화이트, 블랙, 핑크, 라임이었습니다. 이 기기는 모델 번호(D5503)를 통해 식별할 수 있습니다.
Screen not working after replacement
Hello I have Xperia Z1 Compact with a broken screen. I have ordered a replacement screen from ebay. When I connect the screen to the phone and turn it on, nothing happens. I know that the phone works because I hear boot up sound. Also when I press unlock button and then volume up/down keys I can hear the volume change sound. If we assume that the replacement screen is working, what could be wrong with the phone? Is there anything I could do to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
I have a similar problem, i tested the new screen and was satisfactory, however after installing it with the gasket it failed to fire up
의 공유
댓글 달기
답변 1개
가장 유용한 답변
The LCD ribbon cable could have been damaged during installation. Make sure the lcd connector is connected prperly. You might have a defective part, eBay parts are not always the best choice....
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Thanks for the answer. Unless the ribbon was already damaged I doubt I damaged it. Connector is easy to access and I was gentle. I was wondering what chances are there that there is something wrong with the phone itself. For example that metal panel below the display (is that heatsink?) seems a bit detached now. Could a connector itself be a bit detached from the board?
의 공유
댓글 달기
답변을 추가하세요
Ivan Savu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 13
전체 시간: 1,367
