주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ZTE Boost MAX N9520은 5.7형 HD IPS 디스플레이, 4G LTE 및 Android 4.1을 탑재하고 있습니다.
Why won't my external speaker work?
External speaker won't work. Internal work's fine. I can hear music with ear buds, I can hear phone conversation as long as it's not on speaker. My ringer doesn't work as well. Hasn't had any water damage. I did have a cracked screen but it was just replaced profesprofessionally.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi,
How long since it was repaired? Was the ringer function working when you got it back from repair? Does the repairer give a warranty on his work? If it has not worked since his repair (how often do you use the loudspeaker function) it seems very coincidental, contact the repairer and ask. The ringer function (not vibrate) uses the loudspeaker so if it is loose or faulty that is probably why both don't work
의
Why no one can hear me but I contacted hear them
의
댓글 달기
답변 1개
선택된 해법
Hi Faith Randall,
Have you checked the volume setting for the loudspeaker?
Go to :
Menu > Settings > Sound > tap Volumes > slide volume control for Loudspeaker to desired volume.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
Yes I did check the volume
의
댓글 달기
답변을 추가하세요
mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 3
지난 30일: 18
전체 시간: 1,572
