주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Roku 3(모델: 4200)은 2013년 3월 5일에 출시된 3세대 스트리밍 기기입니다. 올바른 입력 단자가 있는 TV나 비디오 디스플레이에 연결하여 콘텐츠를 스트리밍할 수 있습니다.
Volume Button Replacement For enhanced remote
Where can I purchase a replacement momentary pushbutton for the roku 3 enhanced remote?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
I busted out the digital calipers and found the part on Digi-Key. Panasonic EVQP7A01P or EVQP7J01P. The difference is the operating force. I ordered each one to see which one felt better before I soldered it in. The (A) model force is 2.2N and the (J) is 1.6N. They are $.31 each and shipping was $5 for 3 day transit.
Screenshot of spec sheet. This shows drawing No.1 which is the section for the (A) and (J) option. But the full link and ordering links are below.
이미지
Link to full spec sheet
https://b2b-api.panasonic.eu/file_stream...
Link to (A) Model on Digi-Key
https://www.digikey.com/product-detail/e...
Link to (J) Model on Digi-Key
I’ll try to remember to post which one I like better, but if I don’t, well, it’s cheap enough you could order both and make your own decision.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thank you so much for sharing this fix!
의 공유
I just successfully finished my repair! Digi-key was amazingly fast with shipping (which is a real bonus in Canada).
I recommend the lighter-action switch - the J version. Works like a champ.
Pro-tip: I also recommend cutting the old switch in half with sharp side-cutters, to assist in removing the switch without toasting your PC board.
Cheers!
의 공유
댓글 달기
I have the same problem with my Remote, the "up" volume is broke.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
duteycs 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 27
전체 시간: 6,403
