주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
15.6인치 디스플레이. 모델 코드 NP470R5E-K02UB로 식별됨. 이 기기는 2013년 8월에 출시되었음.
Do not attempt keyboard replacement.
Hey everyone,
This isn't so much a question as a word of advise. Do NOT attempt to replace the keyboard on this device without purchasing a new palmrest/top case as well. The keyboard is held in by what looks like plastic rivets, and is VERY difficult to replace on your own. I've attempted a keyboard-only repair a few times, and I won't let it happen again. It takes much too long to tear off all the plastic rivets and glue the new keyboard down, and you end up with a less than satisfactory repair every time.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 1개
Where did you order the palmrest/top case that you recommended. If you could provide the part number, that might be helpful if a future repair is required by someone who reviews the post.
의
댓글 달기
답변 1개
가장 유용한 답변
I had the same experience. Had to completely disassemble the laptop to get to the keyboard, then cut off the plastic rivets with a box cutter to remove it. Well, OK, my student worker did. I supervised. It's nice to have minions. It did turn out well but took a few hours.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
hi brianstrech,
how did you guys glue the keyboard back?
의
댓글 달기
답변을 추가하세요
Max Rysdon 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 31
전체 시간: 1,974
