주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
이 LG Tribute 스마트폰은 모델 번호 LS660으로 식별됩니다. 2014년 10월에 출시되었으며 Android 운영 체제에서 실행됩니다.
Why won't my phone charge?
When I plug my phone in it doesn't recognize that it is charging or connected.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 3개
가장 유용한 답변
Try removing the battery, then plugging in the cord. After at least 30 seconds, add the battery with the cord stil l in. It should take a while, but it will charge.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
It really works too I had so much stuff stored on this phone🤣
댓글 달기
Gus-
If your phone is plugged in to charge but does not recognize a connection then the first thing I would do is test the chord. Either use your chord to try charging another device or use a different chord to charge your device. If your chord is working then my second suggestion would be to clean out the charging port with compressed air. If your chord is good and your port is clean then I would say you might need to replace your charging port. Take a look at the LG Tribute Troubleshooting page.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I had that problem i changed my charger and blow into the pert where charger goes mine was going crazy its fine now
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gustav Wolter 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 13
전체 시간: 7,060
