주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NX30은 렌즈 교환식 미러리스 카메라입니다. HD 비디오 촬영이 가능하며 2014년 2월 18일에 출시되었습니다.
The flash isn't working!
Alright, I bought this camera about 2 weeks ago and have everything still, used it right out of the box until yesterday, when the flash wouldn't work anymore. I've done all I can without breaking the thing, the button doesn't really work so I kinda have to force it open (which I don't want to do because it might break), and then once I do get it open the flash isn't working. Is it possible I need to take it apart and replace the bulb? If so, I'm not really comfortable with that, but is it possible this could be a software issue?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hello William, is the flash bulb slightly dislodged? That may be why the flash head does not open up easily when you press the flash button. You can use a screwdriver to remove the screws holding in the bulb and then adjust the bulb and screw it back in properly. Once the bulb is in properly, the flash might start working again, otherwise you may have a dead bulb.
If the flash bulb is dead, this is an easy fix - you can just follow the guide right here: Samsung NX30 플래시 교체.
All you have to do is get a spare bulb and switch the dead bulb out by unscrewing a couple screws.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
For further help, here is a link to the troubleshooting page for the specific issue: Samsung NX30 Troubleshooting
댓글 달기
답변을 추가하세요
William 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 24
전체 시간: 1,256
