주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony Xperia Z3는 2014년에 출시된 안드로이드 스마트폰으로, 긴 배터리 사용 시간과 내구성으로 알려져 있습니다.
Vibrator motor not working
So I replaced the screen on my Xperia Z3, then I re-installed everyhting, and everything works except the vibrator motor, I thought maybe I broke the motor so I bought a replacement power button assembly (that has the mic and motor) I replaced it, but it still doesn't work. I didn't replace that tiny little piece that it connects to, because frankly I can't find it for sale anywhere. Do you think that is it?
Any solution?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Hi Max
Usually the vibrating motor is on the cable with on/off and volume buttons. If you replace that cable and the motor doesn't work maybe the cable is faulty.
Hope you fix it soon.
댓글 달기
답변 3개
The vibrator motor is connected to the ribbon cable, Next to the motor there is a connector that gets plunged inn. There is a pink rubber insert that covers the motor that helps with vibration and noise. The motor will still work without the pink rubber insert.
That cable is very fragile, most likly it was damaged during installation.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
maybe your screw very tight, loose a bit.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I exactly have a same problem.
I replaced my lcd, then the vibrator & mic doesn't work.. so I replaced the main flexible. The mic is working but the vibrator just stand still.
Still have no idea,
Is there any possibility it caused by the software error or something ?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Max M 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 3,131
