주요 콘텐츠로 건너뛰기
Model A1174과 2 GHz Core Duo 또는 Model A1207과 2.16 또는 2.33 GHz Core 2 Duo
212 질문 전체 보기
Is it possible to upgrade its CPU for a Core2Duo ?
I've read on Hardmac that the CPU of this iMac could be upgraded from CoreDuo to a powerful Core2Duo. Have you ever done it ?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Yes, you can upgrade the Core Duo Imac,
Here is a Guide
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
I finally replace my Core Duo on my iMac from 2006 by a Core 2 Duo 7400 !!! Il works great and the replacement was pretty much easy with patience. I also put a new power supply because the original, a rev.a, seems to cause unpredictable shutdown ... il looks like a component not design by Apple but by my dumb neighbour with his feet ;-)
Again, thx matthewfrey for your precious link.
Cheers from France !
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Yes and no!
The CPU on these models are permanently mounted on the logic board.
However, most all of the parts between the Model A1174 (with a 2 GHz Core Duo processor) and the Model A1207 (with either 2.16 or 2.33 GHz Core 2 Duo processors) are the same. Therefore, you could upgrade to the Core 2 Duo by replacing the logic board.
I hope this helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
This is incorrect. The process is a zif socket: Core Duo CPU upgrade to Core 2 Duo CPU?
댓글 달기
Thanx Ben & thanx a lot Matthewfrey ... I'm going to refresh my iMac !
Happy Xmas & New Year !!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Francois Besson 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 4,624
