주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Coolpix S6800은 12배 광학 줌과 24배 다이내믹 파인 줌 기능을 갖춘 슬림형 Wi-Fi 호환 카메라입니다. 또한 풀 1080p HD 동영상 촬영이 가능하며, 촬영한 영상은 호환 기기로 즉시 전송할 수 있습니다.
memory card is write protected?
I keep getting the write protected code when I put in a memory card. I have tried three different card and get the same message. I have locked and unolocked all three memory cards and still get the message. I have even put scotch tape over the lock unlock area (read about this on you tube). Nothin works. need help.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Take out the card. Switch ON the camera - will probably say "Out of memory" or similar. Switch the camera OFF. Replace the card, hopefully should now be OK
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
my memory card (sandisk 8gb) has a 'lock' switch on the side of the memory card. Slide the switch to the 'not locked' position and re-insert into the camera.
의 공유
댓글 달기
Hi, I recently purchased a Nikon 6800 coolpix camera from Ebay. After a few weeks I though I would try it out. (Note I had an old Nikon-6800 with all of the attachments, but the screen had got a spot on it, etc), that is shy I bought a replacement camera.
New Nikon Camera: I decided to see if it would take a picture. ~~~~ it took 2 pictures, and then the camera screen said "No Memory") So I opened the memory slot and there was no memory card, (Thank you Mr. Seller) These 2 pictures looked fine. Note however, when I hooked the camera up to my MS computer to down load those 2 pictures, the computer did not see the camera.
Luckily I had 32g old memory stick (memory stick was NOT locked) that I must have used on my old camera; so I put that into the new camera.
My computer now saw the New Nikon 6800 Camera.
So I decided to go take some more pictures of the flowers, and when I tried to do itm the screen showed, "No Memory". Note this is with the memory card in the camera.
Now that old memory stick had 11 old pictures on it and I was able to down load those old pictures from the new camera with memory onto my computer, but not the 2 new pictures I just took of the flowers. Note also, these 2 New pictures did not show as being on the memory stick, even though they did come up on the camera screen Nikon 6800 new camera when one looked for old pictures on the camera.
Baffled on what to do???? Please help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
David 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 31
전체 시간: 1,545
