주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1985년 닌텐도(Nintendo) 사에서 북미에 출시한 게임기인 닌텐도 엔터테인먼트 시스템(Nintendo Entertainment System), 모델명 NES-001입니다.
Games only playing in up position
After replacing a 72 pin connector the system will not read the game when pushed down. I will read perfect in the up position. Any ideas on what could be happening?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
Thats weird.
You should fix that.
Thats weird. Did you maybe put the pins the wrong way? If so probally flip it
Ive never come across that.
댓글 달기
답변 3개
가장 유용한 답변
I asked this same question on Reddit.
I've also been Googling around a lot, and I think the consensus is that 3rd-party/aftermarket 72 pin connectors are "just like that," but I find this answer profoundly unsatisfying. It rubs me the wrong way to play the game in the up position. I want it to work how it's "supposed" to work.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
That is a little weird. I do believe that it has to do something with the patent on the way that the item is created or manufactured. When you push the game down the cartridge contacts actually level out this also causes a slight upward push from the carrier tray. This I believe allows the contacts to lose their connection to the game board on the underside. What I would possibly look at is to see if you could modify or bring forward those other pins on the bottom a little higher to make the contact connection on the other side when you do push the game down on the carrier tray.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hey there! Have you tried taking the the cartridges apart, then cleaning them? That has worked for me when restoring NES cartridges. I will, in fact, make a guide on how to clean cartridges on the NES page.
Edit: It's done now! Nintendo Entertainment System 카트리지 청소 방법
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Shauna 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 21
전체 시간: 1,518
